BT.com
Wishlist
HPE HP 16GB (1x16GB) DDR4-2133 ECC Reg Memory Module
HPE HP 16GB (1x16GB) DDR4-2133 ECC...
£341.68
£341.68
Add to wishlist
Delivery
Standard Due date unavailable
Boost the capabilities of your HP Workstation with registered DDR4 memory from HP. Get high reliability and cost savings on high-capacity modules vs. unregistered memory.
HPE - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
HP J9P83AA
1 year warranty
Workstation Z440, Z640, Z840
16 GB
Upgrade Type
System specific
HP J9P83AA
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Registered
Voltage
1.2 V
1 year warranty
HP Workstation Z440, Z640, Z840
Scroll to top
