BT.com
Wishlist
HPE HP 1620-24G Switch 24 ports Managed Rack-Mountable
HPE HP 1620-24G Switch 24 ports...
£188.26
£188.26
Add to wishlist
Delivery
Standard 1-3 working days
The HPE 1620 Gigabit Switch Series is an entry-level, smart-managed switch ideal for small businesses looking for basic network features to enhance network performance but without the added complexity and cost of more advanced switches. Part of the HP OfficeConnect portfolio, these switches are plug-and-play out of the box. An intuitive Web GUI provides ease of access to fine tune switch operation, if necessary. The HPE 1620 Gigabit Switch Series consists of 8-, 24-, and 48-port models that can be rack mounted. Customizable features include VLANs, IEEE802.1p QoS and IGPM Snooping.
HPE 1620-24G - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Throughput (64-byte packet size): up to 35.7 Mpps , Routing/switching capacity: 48 Gbps
MAC Address Table Size
8192 entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, CLI
Flow control, full duplex capability, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Quality of Service (QoS), Jumbo Frames support, fanless, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, dual firmware images, NTP time synchronisation, Loopback, DiffServ Code Point (DSCP) support, cable test
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3az
43.99 cm x 17.3 cm x 4.39 cm
2.2 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
8192 entries
Jumbo Frame Support
10KB
Routing Protocol
1 x MIPS: 500 MHz
RAM
128 MB SDRAM
Flash Memory
32 MB
24 x 1000Base-T - RJ-45 , 1 x console - RJ-45 - management
15 Watt
Rack Mounting Kit
Included
MTBF
123.46 years
CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, ICES-003 Class A, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, FCC Part 15 A, VCCI Class A, CSA 22.2 No. 60950-1
43.99 cm
17.3 cm
4.39 cm
2.2 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.53
Scroll to top
