BT.com
Wishlist
HPE HP 1420-24G-2S Switch
£311.98
£311.98
Add to wishlist
Delivery
Standard Due date unavailable
The HPE 1420 Switch Series consists of unmanaged Gigabit Ethernet switches for small businesses and others looking for plug-and-play basic Layer 2 connectivity for their network, including low-cost PoE+ and 10GbE uplink models. The HPE 1420 Switch Series has four models: 16-port 10/100/1000, 24-port 10/100/1000 with two SFP Gigabit ports, 24-port 10/100/1000 ports of which 12 are PoE+ enabled (124 W PoE budget), and 24-port 10/100/1000 with two SFP+ 10GbE ports. All are fanless. They come with a limited lifetime warranty and 24X7 phone support for 90 days.
HPE 1420-24G-2SFP+ 10G Uplink Switch - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 1 Gigabit / 10 Gigabit SFP+
Performance
Throughput (64-byte packet size): up to 65.5 Mpps , Switching capacity: 88 Gbps
MAC Address Table Size
16384 entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Quality of Service (QoS), fanless, 512KB packet buffer, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
44 cm x 23.8 cm x 4.4 cm
2.9 kg
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16384 entries
Jumbo Frame Support
9216 bytes
Flash Memory
8 MB
24 x 1000Base-T - RJ-45 , 2 x Gigabit / 10Gbit LAN - SFP+
MTBF
109,4 years
CISPR 24, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, CISPR 22, CSA 22.2 No. 60950, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A
44 cm
23.8 cm
4.4 cm
2.9 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - phone consulting - 3 years
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.84
£12.04
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.56
Scroll to top
