BT.com
Wishlist
HPE HP 120GB 6GB SATA 2.5IN RI-PLP SC
HPE HP 120GB 6GB SATA 2.5IN RI-PLP...
£143.68
£143.68
Add to wishlist
Delivery
Standard Due date unavailable
Do you need more performance from your HPE ProLiant Server series or HPE Synergy platforms? HPE Solid State Drives (SSDs) deliver exceptional performance and endurance while reducing power consumption for customers with applications requiring high random read and write IOPs performance. Categorized by Read Intensive (RI), Mixed Use (MU), and Write Intensive (WI), you can choose the right SSD that tailors to your workload demands. Also, you can prevent data loss and monitor the SSD life with HPE SmartSSD Wear Gauge compatibility in management tools. Leveraging NAND Flash technology, they support HPE ProLiant servers including Gen9 and server storage platforms. Available as Small Form Factor (SFF) and Large Form Factor (LFF) hot plug devices, non-hot plug SFF devices, and SFF Quick Release devices, you have great flexibility in your installation. These drives deliver higher performance, better latency, and more power-efficient solutions when compared with traditional rotating media.
HPE Read Intensive-2 - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - hot-swap
120 GB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Power Loss support, 1 DWPD
15 mm
3 years warranty
Bundled with
HP SmartDrive carrier
ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL580 Gen9, DL60 Gen9, DL80 Gen9, ML110 Gen9, ML150 Gen9, ML310e Gen8, XL230a Gen9, XL250a Gen9
120 GB
2.5" SFF
SATA 6Gb/s
15 mm
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
480 MBps (read) / 135 MBps (write)
4KB Random Read
61500 IOPS
4KB Random Write
5400 IOPS
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" SFF
Power Consumption
9 Watt
Limited warranty - 3 years
60 °C
HPE ProLiant DL120 Gen9 (2.5"), DL120 Gen9 Entry (2.5"), DL160 Gen9 (2.5"), DL160 Gen9 Base (2.5"), DL160 Gen9 Entry (2.5"), DL160 Gen9 Performance (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL320e Gen8 Special Server (2.5"), DL320e Gen8 v2 (2.5"), DL320e Gen8 v2 Base (2.5"), DL320e Gen8 v2 Entry (2.5"), DL320e Gen8 v2 Performance (2.5"), DL360 Gen9 (2.5"), DL360 Gen9 Base (2.5"), DL360 Gen9 CMS (2.5"), DL360 Gen9 Entry (2.5"), DL360 Gen9 Performance (2.5"), DL360 Gen9 Special Server (2.5"), DL360e Gen8 Special Server (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Performance (2.5"), DL360p Gen8 Special Server (2.5"), DL380 Gen9 (2.5"), DL380 Gen9 Base (2.5"), DL380 Gen9 Entry (2.5"), DL380 Gen9 High Performance (2.5"), DL380 Gen9 Performance (2.5"), DL380e Gen8 (2.5"), DL380e Gen8 Entry (2.5"), DL380p Gen8 Performance (2.5"), DL385p Gen8 (2.5"), DL385p Gen8 Dedicated Workload (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Storage (2.5"), DL385p Gen8 Storage Centric (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL60 Gen9 (2.5"), DL60 Gen9 Base (2.5"), DL60 Gen9 Entry (2.5"), DL80 Gen9 (2.5"), DL80 Gen9 Base (2.5"), DL80 Gen9 Entry (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML150 Gen9 (2.5"), ML150 Gen9 Base (2.5"), ML150 Gen9 Entry (2.5"), ML150 Gen9 Performance (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML310e Gen8 v2 (2.5"), ML310e Gen8 v2 Base (2.5"), ML310e Gen8 v2 Enty (2.5"), ML310e Gen8 v2 Performance (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL250a Gen9 Accelerator Tray (2.5")
Scroll to top
