BT.com
Wishlist
HPE HP  HP E4210-24G Switch
£1,116.21
£1,116.21
Add to wishlist
Delivery
Standard Due date unavailable
HP E4210G Switch Series are entry-level Gigabit Ethernet LAN switches with enterprise-class quality of service (QoS), security, and management features, delivering high value for network administrators looking for an economical edge device. Available Power over Ethernet (PoE) models are ideal for voice over IP and wireless networking installations, while non-PoE models are also available for simple port expansion. Dual-personality ports allow flexibility, including the ability to add 10 Gigabit Ethernet capability. Setting them apart from lower-end devices, the series switches support an industry-standard command-line interface, Web-based administration, and SNMP management. In addition, they support Intelligent Resilient Framework (IRF) stacking of up to four units.
HPE 4210-24G Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L4 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x shared SFP
MAC Address Table Size
16K entries
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTPS, FTP, TFTP, SSH-2
Full duplex capability, routing, Layer 3 switching, Layer 2 switching, auto-negotiation, BOOTP support, ARP support, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, store and forward, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44.2 cm x 30 cm x 4.3 cm
4 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16K entries
Routing Protocol
Static IP routing
Encryption Algorithm
MD5, TLS, PEAP
Authentication Method
RADIUS, PAP, CHAP, Secure Shell v.2 (SSH2)
X Broadcom BCM5836: 264 MHz
RAM
64 MB
Flash Memory
16 MB Flash
Status Indicators
Port status, power
24 x 1000Base-T - RJ-45 , 1 x console - RJ-45 - management , 4 x SFP (mini-GBIC)
Internal power supply
Rack Mounting Kit
Included
CISPR 22 Class A, IEC 61000-3-2, IEC 61000-3-3, VCCI Class A ITE, EN55024, EN55022 Class A, CSA 22.2 No. 60950, ICES-003 Class A, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A
44.2 cm
30 cm
4.3 cm
4 kg
Limited warranty - lifetime
10 - 95% (non-condensing)
Scroll to top
