BT.com
Wishlist
HPE HP - Hard drive - 500 GB - SATA-600 - 7200 rpm - for Workstation z210
HPE HP - Hard drive - 500 GB -...
£97.33
Hurry, only 2 left in stock!
£97.33
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
SATA 7200 rpm drives are our standard high bandwidth hard drive storage options; most workstation models are also available with high performance 10K rpm rotation speeds. Storage capabilities range up to a massive 2.0 TB.
HP - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
8.89 cm x 10.17 cm x 2.54 cm
Workstation z210, Z220, Z230, Z420, Z620, Z820
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
16 MB
8.89 cm
10.17 cm
2.54 cm
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
HP Workstation z210, Z220, Z230, Z420, Z620, Z820
HPE HP - Hard drive - 500 GB - SATA-600 - 7200 rpm -...
£97.33
Save on this ideal PC Build kit!
Save £9.84
£116.89
Cables - Cables
£97.33
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.61
£100.94
Scroll to top
