BT.com
Wishlist
HPE Enterprise Hard Drive 600GB SAS 12Gb/s
HPE Enterprise Hard Drive 600GB SAS...
£330.02
£330.02
Add to wishlist
Delivery
Standard Due date unavailable
600GB hot-plug SAS hard disk drive - 15,000 RPM, 12Gb/sec transfer rate, 2.5-inch small form factor (SFF), SmartDrive Carrier (SC), Enterprise
HPE Enterprise - hard drive - 600 GB - SAS 12Gb/s
Hard drive - hot-swap
600 GB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
15000 rpm
7.57 cm x 11.87 cm x 1.56 cm
3 years warranty
Bundled with
HP SmartDrive carrier
ProLiant ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5")
600 GB
2.5" SFF
SAS 12Gb/s
Bytes per Sector
512
7.57 cm
11.87 cm
1.56 cm
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
2.9 ms (average) / 5.9 ms (max)
Track-to-Track Seek Time
0.15 ms
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
3 years warranty
Limited warranty - 3 years
10 °C
35 °C
HPE ProLiant ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5")
£330.02
Save on this ideal PC Build kit!
Save £16.94
£355.40
Scroll to top
