BT.com
Wishlist
HPE Emulex-based BL cClass Dual Port Fibre Channel Ada
Delivery
Standard Due date unavailable
The Emulex LPe1105-HP dual port Fibre Channel HBA provides reliable, high-performance 4 Gb/s connectivity, enabling high-availability to scalable storage in order to meet the needs of your demanding applications and environments. Based on the same field-proven ASIC, firmware, and driver technology as Emulex's renowned LPe1150 HBA, the Emulex LPe1105-HP is fully driver compatible with all Emulex HBAs. HP provides powerful installation software to streamline the installation of the Emulex HBA driver and management applications. As a centralized management suite, HBAnywareT incorporates agent technology that provides discovery, reporting and management of local and remote HBAs. Emulex HBAs feature an exclusive firmware-based architecture, which allows firmware and features to be upgraded without taking the server off-line or re-booting, and without the need to upgrade the driver. This provides investment protection of end user hardware and ensures minimum downtime.
Emulex LPe1105-HP - network adapter - 2 ports
Network adapter
Plug-in module
Interface (Bus) Type
PCI Express
PCI Specification Revision
PCIe 1.0a
10.1 cm 11.3 cm
Ports Qty
2 ports
4Gb Fibre Channel
1 year warranty
ProLiant BL280c G6, BL2x220c G6, BL460c G5, BL460c G6, BL460c G7, BL465c G6, BL465c G7, BL490c G6, BL490c G7, BL495c G5, BL495c G6, BL620C G7, BL680c G7, BL685c G6, BL685c G7, SB460, WS460c G6; StorageWorks Network Storage Blade X1800sb G2, X3800sb G2; StorageWorks Network Storage Gateway X3800sb G2
Network adapter - 2 ports
Plug-in module
PCI Express
PCIe 1.0a
Wired
4Gb Fibre Channel
10.1 cm
11.3 cm
1 year warranty
Service & Support Details
Limited warranty - parts - 1 year
10 °C
35 °C
10 - 90%
HPE Integrity BL860c, BL870c , HPE ProLiant BL260c G5, BL280c G6, BL2x220c G5, BL2x220c G5 Server A, BL2x220c G5 Server B, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL460c, BL460c G5, BL460c G6, BL460c G7, BL465c G5, BL465c G6, BL465c G7, BL480c, BL490c G6, BL490c G7, BL495c G5, BL495c G6, BL620C G7, BL680c G5, BL680c G7, BL685c G5, BL685c G6, BL685c G7, SB460c SAN Gateway Storage Server, WS460c G6 Graphics Expansion Blade, WS460c G6 Workstation Blade, xw460c Blade Workstation , HPE StorageWorks Network Storage Blade X1800sb G2, X3800sb G2 , HPE StorageWorks Network Storage Gateway X3800sb G2
Scroll to top
