BT.com
Wishlist
HPE D3700 Storage Enclosure
£1,774.82
£1,774.82
Add to wishlist
Delivery
Standard Due date unavailable
Has your business exceeded your storage capacity? Manage your small and midrange business' growing storage needs by deploying the HP D3000 Enclosures, the next generation 12 Gb SAS low-cost, high-capacity, tiered external storage system. The HP D3000 Enclosures are ideal for your small application environments, remote offices and departmental locations. The new 12 Gb SAS enclosures-Large Form Factor (LFF) D3600 with 12 drive bays and Small Form Factor (SFF) D3700 with 25 drive bays-offer flexible, modular solutions to simplify capacity expansion of HP ProLiant server and HP BladeSystem environments to external storage without having to make the full move to SAN or NAS. This allows you to buy what is needed today and purchase additional capacity as data storage needs grow. D3000 Enclosures support HP SmartDrive Carrier. Buy and maintain a common set of HP ProLiant drives for Gen8/9 ProLiant servers. Total support can grow up to 96 LFF or 200 SFF drives.
HPE D3700 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
30 TB
0 (installed) / 25 (max)
Supported Drives
SAS-3
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
44.8 cm x 54.6 cm x 8.7 cm
24.9 kg
3 years warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
25
Supported Drives
SAS-3
Storage
30 TB
Hard Drive
No HDD
Expansion Bays
25 (total) / 25 (free) x hot-swap - 2.5" SFF
1 x SAS 12Gb/s
92% efficiency power supply
1 x mini SAS HD cable - 50 cm
80 PLUS Gold
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
460 Watt
44.8 cm
54.6 cm
8.7 cm
24.9 kg
Limited warranty - parts - 3 years
10 °C
10 - 90%
Sound Emission
53 dBA
Scroll to top
