BT.com
Wishlist
HPE BLc7000 Platinum Encl 1 phase 6 supplies RoHS Insight Lic
Delivery
Standard Due date unavailable
The BladeSystem c7000 enclosure provides all the power, cooling, and I/O infrastructure needed to support modular server, interconnect, and storage components today and throughout the next several years. The enclosure is 10U high and holds up to 16 server and/or storage blades plus optional redundant network and storage interconnect modules. It includes a shared 7.1 Tbps high-speed NonStop mid-plane for wire-once connectivity of server blades to network and shared storage. Power is delivered through a pooled-power backplane, and power input flexibility is provided with choices of single-phase AC input, 3-phase AC input, -48V DC input, and high voltage DC input.
HPE BLc7000 Enclosure - rack-mountable - up to 16 blades
System cabinet
Bundled with
ROHS 16 Insight Control Licenses
Rack-mountable
Supported Blades Qty
Up to 16
Built-in Devices
Status LCD, HP Onboard Administrator with KVM Option
Power supply - hot-plug 2400 Watt
75.89 cm x 60.65 cm x 101.29 cm
136.08 kg
3 years warranty
Bundled with
Rack-mountable
Up to 16
Built-in Devices
Cooling System
Rear: fan x 10 / hot-swap , Rear: fan mount x 10 / hot-swap
RoHS, WEEE
Installed Qty
6
Power Provided
2400 Watt
75.89 cm
60.65 cm
101.29 cm
136.08 kg
Limited warranty - parts and labour - 3 years - on-site
Scroll to top
