BT.com
Wishlist
HPE BLC VC 1GB RJ-45 SFP Option Kit
HPE BLC VC 1GB RJ-45 SFP Option...
£190.42
£190.42
Add to wishlist
Delivery
Standard 1-3 working days
The HP BladeSystem c-Class SFP Transceivers provide high performance Ethernet connectivity and bring customers more choices for using either copper or optical cables.
HPE - SFP (mini-GBIC) transceiver module - Ethernet, Fast Ethernet, Gigabit Ethernet
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
HP 1/10Gb-F Virtual Connect Ethernet Module, 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem; HPE 6120G/XG Blade Switch, 6120XG Blade Switch; BLc3000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; Virtual Connect Flex-10
Plug-in module
Wired
Cabling Type
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-T
Compatible Slots
1 x SFP (mini-GBIC)
HP 1/10Gb-F Virtual Connect Ethernet Module, 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem , HPE 6120G/XG Blade Switch, 6120XG Blade Switch , HPE BLc3000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE Virtual Connect Flex-10
Scroll to top
