BT.com
Wishlist
HPE 8TB 6G SATA 7.2K 3.5" 512e SC Helium Hard Drive
HPE 8TB 6G SATA 7.2K 3.5" 512e SC...
£667.29
Hurry, only 1 left in stock!
£667.29
Add to wishlist
Delivery
Standard 1-3 working days
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline Helium - hard drive - 8 TB - SATA 6Gb/s
Hard drive - hot-swap
8 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Advanced format 512e, filled with Helium
110.7 mm x 188.7 mm x 26.4 mm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL120 Gen9, DL120 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL320e Gen8 Special Server (3.5"), DL320e Gen8 v2 (3.5"), DL320e Gen8 v2 Base (3.5"), DL320e Gen8 v2 Entry (3.5"), DL320e Gen8 v2 Performance (3.5"), DL60 Gen9 (3.5"), DL60 Gen9 Base (3.5"), DL60 Gen9 Entry (3.5"), DL80 Gen9 Entry (3.5"), ML150 Gen9 (3.5"), ML150 Gen9 Base (3.5"), ML150 Gen9 Entry (3.5"), ML150 Gen9 Performance (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5"); StoreEasy 1650
8 TB
3.5" LFF
SATA 6Gb/s
Bytes per Sector
512
110.7 mm
188.7 mm
26.4 mm
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average) / 16 ms (max)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" LFF
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant DL120 Gen9 (3.5"), DL120 Gen9 Entry (3.5"), DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL320e Gen8 Special Server (3.5"), DL320e Gen8 v2 (3.5"), DL320e Gen8 v2 Base (3.5"), DL320e Gen8 v2 Entry (3.5"), DL320e Gen8 v2 Performance (3.5"), DL60 Gen9 (3.5"), DL60 Gen9 Base (3.5"), DL60 Gen9 Entry (3.5"), DL80 Gen9 Entry (3.5"), ML150 Gen9 (3.5"), ML150 Gen9 Base (3.5"), ML150 Gen9 Entry (3.5"), ML150 Gen9 Performance (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5") , HPE StoreEasy 1650
£667.29
Save on this ideal PC Build kit!
Save £16.94
£692.67
Cables - Cables
£667.29
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.45
£670.74
Scroll to top
