BT.com
Wishlist
HPE 8GB KIT 2RX4 PC3L-10600R9 RDIM
Price Drop
£130.24
Price Drop
Last Few Remaining
Clearance
Price Drop!
Hurry, only 1 left in stock!
£130.24
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
HPE Low Power kit - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Dual rank, registered
HP 604502-B21
1 year warranty
ProLiant BL465c G7, BL685c G7, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G7, DL585 G7 Base, SL165s G7, SL165s G7 Base, SL165s G7 Entry, SL165s G7 Performance, SL165z G7
8 GB
Upgrade Type
System specific
HP 604502-B21
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Chips Organization
X4
Compatible Slots
1 x memory - DIMM 240-pin
1 year warranty
HPE ProLiant BL465c G7, BL685c G7, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G7, DL585 G7 Base, SL165s G7, SL165s G7 Base, SL165s G7 Entry, SL165s G7 Performance, SL165z G7
Scroll to top
