BT.com
Wishlist
HPE 7.3KVA 230V 24OUT Power Distribution Unit
HPE 7.3KVA 230V 24OUT Power...
£457.60
£457.60
Add to wishlist
Delivery
Standard Due date unavailable
Do you need rack level power monitoring over the network? With billing grade accuracy the HPE Metered Power Distribution Units are an excellent choice for data centers wanting to make the most of circuit capacity or for co-location facilities needing to precisely track power usage for billing purposes. HPE Metered PDUs have a low profile single piece design with multiple mounting options and ease of access to rear devices for maintenance. Designed for HPE racks but will also work in a large variety of third party racks as well using standard button and keyhole mounting. They can be installed on either side of the rack with outlets facing the back of the rack for easy access and improved clearance. Also for higher power density they can be installed side by side on both sides of the rack with the outlets facing in towards the center of the rack. HPE Metered PDUs are available in 1U and vertical form factors in single and 3-phase models and are back by HPE's limited 3-year warranty.
HPE Remote Monitored PDU Mid Height - power distribution unit - 7360 VA
Power distribution unit - rack-mountable
4.77 kg
Input Voltage
230 V
Power Capacity
7360 VA
Input Connectors
1 x power IEC 60309 332P6
Output connectors
20 x power IEC 60320 C13 , 4 x power IEC 60320 C19
Ethernet
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
Cable tie
5.2 cm x 142.54 cm x 5.2 cm
3 years warranty
ProLiant ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance
Input Voltage
230 V
Input Voltage Range
AC 200 - 240 V
Input Connectors
Max Electric Current
32 A
Power Capacity
7360 VA
Circuit Protection
Circuit breaker
Remote Management Interface
Ethernet
1 x management - RJ-45
Cable tie
Power cable - integrated - 2.4 m , Network cable - external - 1.83 m , Serial cable - external - 1.83 m
Rack Mounting Kit
Included
LCD display, email alerts support
TUV, KCC, WEEE, KC, EAC
Limited warranty - 3 years
10 °C
60 °C
10 - 90%
5.2 cm
142.54 cm
5.2 cm
4.77 kg
HPE ProLiant ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance
Scroll to top
