BT.com
Wishlist
HPE 5406R zl2 Switch
£1,328.16
Hurry, only 1 left in stock!
£1,328.16
Add to wishlist
Delivery
Standard 1-3 working days
The Aruba 5400R zl2 Switch Series is an industry-leading mobile campus access solution with HPE Smart Rate multi-gigabit ports for high-speed connectivity and bandwidth for next wave 802.11ac devices. It brings enterprise-class resiliency and innovative flexibility and scalability to mobile-first networks. Robust virtualization with AllianceOne solutions, hitless failover, QoS, and security with full L3 features and flexible connectivity including 40 Gigabit Ethernet ports and full PoE+, the Aruba 5400R requires no add-on software licensing and is SDN ready with OpenFlow support.
Aruba 5406R zl2 - switch - Managed - rack-mountable
Switch - Managed
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
Power Over Ethernet (PoE)
PoE+
Performance
Throughput: 392.8 Mbps , Routing/switching capacity: 528 Gbps , Switching fabric bandwidth: 1015 Gbps
IPv4 routing table entries: 10000 , IPv6 routing table entries: 5000
MAC Address Table Size
64K entries
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, IGMP, OSPFv2, static IP routing, IGMPv3, OSPFv3
Remote Management Protocol
SNMP 1, RMON 2, RMON, SNMP 3, SNMP 2c, HTTP, SSH-2, CLI, XRMON
VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, half duplex mode, full duplex mode, sFlow, Virtual Route Redundancy Protocol (VRRP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, STP Root Guard, Uni-Directional Link Detection (UDLD), Rapid Per-VLAN Spanning Tree Plus (PVRST+), LLDP support, Port Security, DHCP protection, Class of Service (CoS), sFlow v5, Generic Attribute Registration Protocol (GARP), Type of Service (ToS)
IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44.45 cm x 45.09 cm x 17.53 cm
11.11 kg
Bundled Services
Switch - Managed
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
PoE+
Performance
64K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Expansion Slots
6 (total) / 6 (free) x Expansion Slot
Internal power supply
Installed Qty
0 (installed) / 2 (max)
Fan tray
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, CSA 22.2 No. 60950, FCC Part 15, EN 61000-4-11
44.45 cm
45.09 cm
17.53 cm
11.11 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - lifetime
45 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Scroll to top
