BT.com
Wishlist
HPE 500W Flex Slot Hot Plug/Redundant Power Supply Kit
HPE 500W Flex Slot Hot...
£196.59
Hurry, only 1 left in stock!
£196.59
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
How do you improve data center power efficiency without impacting IT performance? HP Flexible Slot Power Supplies provide up to 96% power efficiency with 80Plus Titanium-certified power supplies that lower server power requirements and reduce power waste in your data center. Flex Slot Power Supplies have a form factor that is 25% smaller than previous generation power supplies, providing more space to add additional server options and improve the performance of your servers. Flex Slot Power Supplies provide fast, tool-less hot plug access to server power supplies for greater serviceability and are supported across the entire ProLiant DL300 Gen9 Server family, simplifying your spares strategy and further reducing data center costs. Are you currently using or interested in the HP Power Discovery Services solution? Support for Power Discovery Services can be added to all ProLiant DL300 Gen9 Servers with the Flex Slot 800W Titanium or Flex Slot 1400W Platinum Plus Power Supply option.
HPE - power supply - hot-plug / redundant - 500 Watt - 564 VA
Power supply - hot-plug / redundant - plug-in module
Specification Compliance
Flex Slot
80 PLUS Certification
80 PLUS Platinum
910 g
Input Voltage
AC 100-240 V
Power Capacity
500 Watt / 564 VA
6.8 cm x 22.53 cm x 4.04 cm
ProLiant DL360 Gen9 CMS (500 Watt), DL380 Gen9 (500 Watt), DL380 Gen9 Base (500 Watt), DL380 Gen9 Entry (500 Watt), DL380 Gen9 Performance (500 Watt), ML350 Gen9 (500 Watt), ML350 Gen9 Base (500 Watt), ML350 Gen9 Entry (500 Watt), ML350 Gen9 Performance (500 Watt)
Flex Slot
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
500 Watt / 564 VA
Efficiency
94%
80 PLUS Platinum
UL, TUV, C-Tick, BSMI, cUL, CCC, KCC, WEEE, CISPR
5 °C
55 °C
5 - 95% (non-condensing)
6.8 cm
22.53 cm
4.04 cm
910 g
Shipping Width
37.47 cm
Shipping Depth
14.61 cm
Shipping Height
19.05 cm
Shipping Weight
1.59 kg
HPE ProLiant DL360 Gen9 CMS (500 Watt), DL380 Gen9 (500 Watt), DL380 Gen9 Base (500 Watt), DL380 Gen9 Entry (500 Watt), DL380 Gen9 Performance (500 Watt), ML350 Gen9 (500 Watt), ML350 Gen9 Base (500 Watt), ML350 Gen9 Entry (500 Watt), ML350 Gen9 Performance (500 Watt)
£196.59
Save on this ideal PC Build kit!
Save £10.63
£215.76
Scroll to top
