Click to visit BT.com
BT.com
Wishlist
HPE 500GB 7.2K 2.5 MDL SATA 1Y WTY HDD
Quicklinx: 6B56WS00
Mfr#: 507750-B21
£199.88
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 500 GB - SATA 3Gb/s
Hard drive - hot-swap
500 GB
2.5" SFF
SATA 3Gb/s
Data Transfer Rate
300 MBps
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
7.2 cm x 13.7 cm x 6 cm
1 year warranty
HPE P2000, P2000 G3; Modular Smart Array P2000 2.5-in, P2000 G3; ProLiant BL460c G6, BL460c G7, BL465c G5, BL465c G6, BL465c G7, BL620C G7, BL680c G5, BL680c G7, BL685c G5, BL685c G6, BL685c G7, DL120 G7, DL160 G6, DL165 G7, DL170h G6, DL360 G5, DL360 G6, DL360 G7, DL365 G5, DL370 G6, DL380 G5, DL380 G6, DL380 G7, DL385 G5p, DL385 G6, DL385 G7, DL580 G5, DL580 G7, DL585 G5, DL585 G6, DL585 G7, ML110 G7, ML350 G5, ML350 G6, ML370 G5, ML370 G6; StorageWorks D2200; StorageWorks Disk Enclosure D2700; StorageWorks Modular Smart Array P2000 2.5-in, P2000 G3; StorageWorks Network Storage Blade X1800sb G2; StorageWorks Network Storage Gateway X3800sb G2; StorageWorks Network Storage System X1800 G2
500 GB
2.5" SFF
SATA 3Gb/s
Bytes per Sector
512
7.2 cm
13.7 cm
6 cm
Performance
Drive Transfer Rate
300 MBps (external)
Seek Time
8.2 ms (average) / 17.55 ms (max)
Track-to-Track Seek Time
0.5 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 2.5" SFF - hot-swap
1 year warranty
Service & Support Details
Limited warranty - 1 year
10 °C
35 °C
HPE P2000 DC-power SFF Chassis, P2000 G3 FC Dual Controller, P2000 G3 iSCSI Dual Controller , HPE Modular Smart Array P2000 2.5-in Drive Bay Chassis, P2000 G3 FC Dual Controller SFF Modular Smart Array System, P2000 G3 FC MSA Dual Controller Virtualization SAN Starter Kit, P2000 G3 FC/iSCSI Dual Combo Controller SFF Modular Smart Array System, P2000 G3 iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle, P2000 G3 SAS Dual Controller SFF Array System , HPE ProLiant BL460c G7, BL465c G6, BL465c G7, BL620C G7, BL680c G7, BL685c G6, BL685c G7, DL120 G7 (2.5"), DL165 G7 (2.5"), DL165 G7 Performance (2.5"), DL165 G7 Special Server (2.5"), DL170h G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Special Server (2.5"), DL380 G6 (2.5"), DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G7 (2.5"), DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G6 (2.5"), DL385 G6 Base (2.5"), DL385 G6 Entry (2.5"), DL385 G6 High Performance (2.5"), DL385 G6 Performance (2.5"), DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, ML110 G7 (2.5"), ML370 G6 Entry, ML370 G6 Special Server (2.5") , HPE StorageWorks D2200sb PCIe Storage Blade , HPE StorageWorks Disk Enclosure D2700 , HPE StorageWorks Modular Smart Array P2000 2.5-in Drive Bay Chassis, P2000 G3 FC/iSCSI Dual Combo Controller SFF Array , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3800sb G2 , HPE StorageWorks Network Storage System X1800 G2
HPE 500GB 7.2K 2.5 MDL SATA 1Y WTY HDD Bundle deal on HPE 500GB 7.2K 2.5 MDL SATA 1Y WTY HDD
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£209.87
saving £4.99
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£201.66
saving £1.78
