BT.com
Wishlist
HPE 500GB 6G SATA 7.2K 2.5IN SF
£173.73
£173.73
Add to wishlist
Delivery
Standard Due date unavailable
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 500 GB - SATA 6Gb/s
Hard drive - hot-swap
500 GB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant BL420c Gen8 (2.5"), BL460c Gen8 (2.5"), BL465c Gen8 (2.5"), DL160 Gen8 (2.5"), DL360e Gen8 (2.5"), DL360p Gen8 (2.5"), DL380e Gen8 (2.5"), DL380p Gen8 (2.5"), DL385p Gen8 (2.5"), ML350e Gen8 (2.5"), ML350p Gen8 (2.5"), SL230s Gen8 (2.5"), SL250s Gen8 (2.5")
500 GB
2.5" SFF
SATA 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" SFF
Limited warranty - 1 year
HPE ProLiant BL460c Gen8 (2.5"), BL660c Gen8 (2.5"), BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL360e Gen8 (2.5"), DL360e Gen8 Base (2.5"), DL360e Gen8 Entry (2.5"), DL360e Gen8 Special Server (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL380e Gen8 (2.5"), DL380e Gen8 Entry (2.5"), DL380e Gen8 High Performance (2.5"), DL380e Gen8 Storage (2.5"), DL385p Gen8 (2.5"), DL385p Gen8 Dedicated Workload (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Maximized Consolidation (2.5"), DL385p Gen8 Storage (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML310e Gen8 v2 Base (2.5"), ML350e Gen8 (2.5"), ML350e Gen8 v2 (2.5"), ML350p Gen8 (2.5"), ML350p Gen8 Special Server (2.5"), SL250s Gen8 2U PCIe Gen3 Left Tray (2.5"), SL250s Gen8 2U PCIe Gen3 Right Tray (2.5"), SL250s Gen8 Left Tray (2.5"), SL250s Gen8 Right Tray (2.5"), SL270s Gen8 1U Left Half Width Tray (2.5"), SL270s Gen8 1U Right Half Width Tray (2.5"), SL270s Gen8 Base 4U Left Half Width Tray (2.5"), SL270s Gen8 Base 4U Right Half Width Tray (2.5"), SL270s Gen8 SE 4U Left Tray (2.5"), SL270s Gen8 SE 4U Right Tray (2.5"), SL4545 G7 (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5"), XL170r Gen9 (2.5"), XL190r Gen9 (2.5"), XL220a Gen8 v2 (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL250a Gen9 Accelerator Tray (2.5")
Scroll to top
