BT.com
Wishlist
HPE 500GB 6G SAS 7.2K 2.5IN 1Y WT MDL HDD
HPE 500GB 6G SAS 7.2K 2.5IN 1Y WT...
£188.19
£188.19
Add to wishlist
Delivery
Standard 1-3 working days
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Dual Port Midline - hard drive - 500 GB - SAS 6Gb/s
Hard drive - hot-swap
500 GB
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
1 year warranty
ProLiant BL460c G6, BL460c G7, BL465c G5, BL465c G6, BL465c G7, BL480c, BL620C G7, BL680c G5, BL680c G7, BL685c G5, BL685c G6, BL685c G7, DL120 G7, DL160 G6, DL160se G6, DL165 G7, DL180 G6, DL320 G6, DL360 G5, DL360 G6, DL360 G7, DL365 G5, DL370 G6, DL380 G5, DL380 G6, DL380 G7, DL385 G5p, DL385 G6, DL385 G7, DL580 G5, DL580 G7, DL585 G5, DL585 G6, DL585 G7, DL785 G5, DL785 G6, ML110 G7, ML350 G5, ML350 G6, ML370 G5, ML370 G6, WS460c G6
500 GB
2.5" SFF
SAS 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
2 x SAS 6Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 1 year
HPE ProLiant BL460c G6 (2.5"), BL460c G7 (2.5"), BL465c G6 (2.5"), BL465c G7 (2.5"), BL620C G7 (2.5"), BL680c G7 (2.5"), BL685c G6 (2.5"), BL685c G7 (2.5"), DL120 G7 (2.5"), DL160 G6 (2.5"), DL160 G6 Special Server (2.5"), DL160se G6 (2.5"), DL165 G7 (2.5"), DL165 G7 Performance (2.5"), DL165 G7 Special Server (2.5"), DL180 G6 (2.5"), DL180 G6 Special Server (2.5"), DL320 G6 (2.5"), DL360 G6 (2.5"), DL360 G6 Base (2.5"), DL360 G6 Efficiency (2.5"), DL360 G6 Entry (2.5"), DL360 G6 Performance (2.5"), DL360 G7 (2.5"), DL360 G7 Base (2.5"), DL360 G7 Central Management Server (2.5"), DL360 G7 Efficiency (2.5"), DL360 G7 Entry (2.5"), DL360 G7 Performance (2.5"), DL360 G7 Special Server (2.5"), DL370 G6 (2.5"), DL370 G6 Base (2.5"), DL370 G6 High Performance (2.5"), DL370 G6 Performance (2.5"), DL370 G6 Special Server (2.5"), DL380 G6 (2.5"), DL380 G6 Base (2.5"), DL380 G6 Entry (2.5"), DL380 G6 High Efficiency (2.5"), DL380 G6 Performance (2.5"), DL380 G7 (2.5"), DL380 G7 Base (2.5"), DL380 G7 Efficiency (2.5"), DL380 G7 Entry (2.5"), DL380 G7 Performance (2.5"), DL380 G7 Special Server (2.5"), DL385 G5p Entry (2.5"), DL385 G6 (2.5"), DL385 G6 Base (2.5"), DL385 G6 Entry (2.5"), DL385 G6 High Performance (2.5"), DL385 G6 Performance (2.5"), DL385 G7 (2.5"), DL385 G7 Base (2.5"), DL385 G7 Entry (2.5"), DL385 G7 HE (2.5"), DL385 G7 Performance (2.5"), DL580 G5 Highly Serviceable Tower (2.5"), DL580 G7 (2.5"), DL580 G7 Base (2.5"), DL580 G7 High Performance (2.5"), DL585 G5 Performance (2.5"), DL585 G6 (2.5"), DL585 G6 Base (2.5"), DL585 G6 Performance (2.5"), DL585 G7 (2.5"), DL585 G7 Base (2.5"), DL585 G7 Performance (2.5"), DL785 G6 (2.5"), DL785 G6 Base (2.5"), DL785 G6 Performance (2.5"), ML110 G7 (2.5"), ML350 G6 (2.5"), ML350 G6 Base (2.5"), ML350 G6 Performance (2.5"), ML350 G6 Special Server (2.5"), ML370 G6 (2.5"), ML370 G6 Base (2.5"), ML370 G6 Entry (2.5"), WS460c G6 Workstation Blade (2.5")
Scroll to top
