BT.com
Wishlist
HPE 4U 8 Small Form Factor Hot Plug Hard Drive Cage Kit
Delivery
Standard Due date unavailable
HP 4U 8 Small Form Factor Hot Plug Hard Drive Cage Kit
1.36 kg
Minimum dimensions (W x D x H)
19.58 x 23.8 x 21.29 cm
Designed for ProLiant ML310e Gen8, ML310e Gen8 base, ML310e Gen8 entry, ML310e Gen8 performance
  • Hard drive size: 63.5 mm
  • Number of hard drives supported: 8
  • Rack capacity: 4U
  • Device type: storage drive cage
HPE - storage drive cage
Storage drive cage
Expansion Bays
8 x hot-swap - 2.5" SFF
Hard Drive Form Factor Compatibility
2.5"
1.36 kg
ProLiant ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5")
Storage drive cage
2.5"
Bays
1.36 kg
HPE ProLiant ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5")
Scroll to top
