BT.com
Wishlist
HPE 4TB 6G SATA 7.2K 3.5IN
£352.81
£352.81
Add to wishlist
Delivery
Standard Due date unavailable
Do you have non mission-critical applications that require economical high capacity and reliability hard disk drives? HPE Server SATA Hard Drives are built for reliability and larger capacity needs for today's non mission-critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less.
HPE Server SATA Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All Hewlett Packard Enterprise hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments.
Before final certification, all HPE Server SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
What's new
Up to 10 TB SATA 7.2K LFF 512e Helium Hard Disk Drives
Designed and Engineered to Provide Reliable and Cost Efficient Data Storage
  • The HPE Server SATA Hard Drives increase reliability and lower start-up costs without sacrificing reliability with non-mission critical hard drives at the lowest $/GB.
  • Both cost and capacity optimized solutions provide up to 10 TB of storage in a single device. Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) that are available in a wide variety of capacity points.
  • Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.
  • 6 Gb/sec data transfer rate supporting existing servers.
HPE Performance - hard drive - 4 TB - SATA 6Gb/s
Hard drive - hot-swap
4 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), advanced format 512e
105.8 mm x 170 mm x 26.8 mm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL120 Gen9, DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL380p Gen8, DL385p Gen8, DL80 Gen9, ML150 Gen9, ML350 Gen9; StoreEasy 1650
4 TB
3.5" LFF
SATA 6Gb/s
Bytes per Sector
512
105.8 mm
170 mm
26.8 mm
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
7.6 ms (average) / 15 ms (max)
Track-to-Track Seek Time
0.25 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" LFF
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant DL120 Gen9 (3.5"), DL120 Gen9 Entry (3.5"), DL160 Gen8 (3.5"), DL160 Gen8 Base (3.5"), DL160 Gen8 Entry (3.5"), DL160 Gen8 Performance (3.5"), DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL320e Gen8 Special Server (3.5"), DL320e Gen8 v2 (3.5"), DL320e Gen8 v2 Base (3.5"), DL320e Gen8 v2 Entry (3.5"), DL320e Gen8 v2 Performance (3.5"), DL360 Gen9 (3.5"), DL360 Gen9 Base (3.5"), DL360 Gen9 CMS (3.5"), DL360 Gen9 Entry (3.5"), DL360 Gen9 Performance (3.5"), DL380p Gen8 (3.5"), DL380p Gen8 Base (3.5"), DL380p Gen8 Entry (3.5"), DL380p Gen8 High Performance (3.5"), DL380p Gen8 Performance (3.5"), DL380p Gen8 Special (3.5"), DL385p Gen8 (3.5"), DL385p Gen8 Dedicated Workload (3.5"), DL385p Gen8 Entry (3.5"), DL385p Gen8 Maximized Consolidation (3.5"), DL385p Gen8 Storage (3.5"), DL385p Gen8 Storage Centric (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), ML150 Gen9 (3.5"), ML150 Gen9 Base (3.5"), ML150 Gen9 Entry (3.5"), ML150 Gen9 Performance (3.5"), ML350 Gen9 (3.5"), ML350 Gen9 Base (3.5"), ML350 Gen9 Entry (3.5"), ML350 Gen9 Performance (3.5") , HPE StoreEasy 1650
£352.81
Save on this ideal PC Build kit!
Save £16.90
£378.16
Scroll to top
