BT.com
Wishlist
HPE 4GB KIT 2RX8 PC3-10600E UDIMM
£102.10
£102.10
Add to wishlist
Delivery
Standard Due date unavailable
Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
HPE - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Dual rank, unbuffered
ProLiant BL465c G7, DL385 G7 HE, SL165s G7, SL165z G7, SL335s G7 1U Left Tray Node Server, SL335s G7 1U Right Tray Node Server
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL465c G7, DL385 G7 HE, SL165s G7, SL165z G7, SL335s G7 1U Left Tray Node Server, SL335s G7 1U Right Tray Node Server
Scroll to top
