BT.com
Wishlist
HPE 4GB(1X4GB)DDR3-1333 ECC MEMORY
Delivery
Standard Due date unavailable
Boost the capabilities of your HP Workstation and keep it performing reliably with HP DDR3 memory. Upgrading your memory is a cost-effective way to improve system performance when insufficient memory and hard drive paging is slowing your applications down.
HPE - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Unbuffered
HP NL797AA
1 year warranty
Workstation z200, z400, z600, z800
4 GB
Upgrade Type
System specific
HP NL797AA
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
1 year warranty
HP Workstation z200, z400, z800 , HPE Workstation z600
Scroll to top
