BT.com
Wishlist
HPE 4GB 1600MHz PC3-12800 SO DIMM 204-pin Unbuffered non-ECC Memory Module
HPE 4GB 1600MHz PC3-12800 SO DIMM...
£76.15
16 in stock
£76.15
Add to wishlist
Delivery
Standard 3-5 working days
Maximize your business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
  • Dual channel configuration - HP Desktops feature motherboards designed with two memory channels instead of a single channel.
  • Reduce system latencies and significantly improve your system performance with dual channel memory configurations by utilizing the theoretical bandwidth of two memory modules instead of one.
  • Expect fast start-up times with reduced delays during routine operations and system maintenance functions. Meet everyday workloads head on, and run more programs simultaneously. Easily toggle back and forth between several open applications with noticeable speed.
  • Your performance is our business. Each HP Memory model undergoes a rigorous supplier qualification processes for ensured quality and reliability in a variety of networked environments.
  • Dual Channel memory configuration requires the population of symmetric memory in each of the two memory channels (i.e. 2x256).
HP - DDR3 - 4 GB - SO-DIMM 204-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Unbuffered
Compaq CQ58; Presario CQ42, CQ57, CQ58, CQ62; Pavilion dm1, dv3, dv5, DV6, dv7; ProBook 4340, 4440, 4540, 4740
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
Compaq CQ58-200SO, CQ58-201SG, CQ58-202SD, CQ58-202SS, CQ58-202TU, CQ58-206SD, CQ58-206SL, CQ58-210SW, CQ58-215EW, CQ58-216SL, CQ58-217SL, CQ58-218SL, CQ58-219SL, CQ58-221SL, CQ58-222SL, CQ58-225EL, CQ58-225SL, CQ58-237SF, CQ58-250EC, CQ58-250SC, CQ58-250SG, CQ58-251SH, CQ58-252SA, CQ58-253SS, CQ58-260EA, CQ58-261EA, CQ58-270SO, CQ58-271SD, CQ58-276SD, CQ58-282SG, CQ58-295EG, CQ58-300SA, CQ58-300SB, CQ58-300SW, CQ58-301SL, CQ58-301SS, CQ58-301SW, CQ58-302SA, CQ58-302SP, CQ58-303SD, CQ58-304SA, CQ58-305EW, CQ58-305SA, CQ58-306SD, CQ58-307SL, CQ58-311SL, CQ58-313ES, CQ58-313SS, CQ58-319EW, CQ58-320EW, CQ58-325SR, CQ58-330SF, CQ58-347SG, CQ58-350SG, CQ58-351EO, CQ58-351SC, CQ58-351SO, CQ58-353SO, CQ58-373SD, CQ58-392SG, CQ58-bf9WM, CQ58-d01SA, CQ58-d28SA, CQ58-d36SF, CQ58-d50SO, CQ58-d56SR , Compaq Presario CQ57-386NR, CQ57-420SW, CQ57-430SW, CQ57-431SC, CQ57-441SL, CQ58-100SF, CQ58-100SH, CQ58-124SZ, CQ58-135SW, CQ58-145SW, CQ58-150SL, CQ58-200SG, CQ58-203SD, CQ58-230SF, CQ58-252SS, CQ58-303SO , HP Pavilion dm1-4340sf, dv7-4020em, dv7-4020es, dv7-4030em, dv7-4030si, dv7-4033tx, dv7-4060si, dv7-4077cl, dv7-4100em, dv7-4103sg, dv7-4105sw, dv7-4106el, dv7-4106sg, dv7-4109eg, dv7-4110sw, dv7-4111ez, dv7-4119sz, dv7-4120em, dv7-4120ew, dv7-4130ew, dv7-4139eo, dv7-4140ef, dv7-4140ew, dv7-4141eb, dv7-4141ed, dv7-4141sa, dv7-4143ea, dv7-4143ed, dv7-4150ed, dv7-4150em, dv7-4150sg, dv7-4152ef, dv7-4152sf, dv7-4156sg, dv7-4157sg, dv7-4158sg, dv7-4160sf, dv7-4161sf, dv7-4161ss, dv7-4165dx, dv7-4167ef, dv7-4168sf, dv7-4169ef, dv7-4170eg, dv7-4170ss, dv7-4171sf, dv7-4172sf, dv7-4174sf, dv7-4177nr, dv7-4190ef, dv7-4260ca, dv7-4269wm, dv7-4270us, dv7-4285dx, dv7-4288ca, dv7-4294nr, dv7-4295us, dv7-4296nr, dv7-4300el, dv7-4301sg, dv7-4310ef, dv7-4310sf, dv7-4320el, dv7-4350ec, dv7-4362ef, dv7-4362sf, dv7-4372ef, dv7-4380es, dv7-4381eg, dv7-4381sg, dv7-5003tx, dv7-5004tx, dv7-5005tx, dv7-5011tx, dv7-5050es, dv7-5070ca, dv7-5090ef
HPE 4GB 1600MHz PC3-12800 SO DIMM 204-pin Unbuffered...
£76.15
Save on this ideal PC Build kit!
Save £8.43
£95.37
Scroll to top
