BT.com
Wishlist
HPE 4GB (1x4GB) DDR3-1866 MHz ECC Registered RAM
HPE 4GB (1x4GB) DDR3-1866 MHz ECC...
£110.61
£110.61
Add to wishlist
Delivery
Standard Due date unavailable
Boost the capabilities of your HP Workstation and newest multi-core processors. Choose ultra-fast 2 GB, 4 GB, 8 GB, or 16 GB 1866 MHz DDR3 memory from HP, a cost-effective way to improve system performance and application responsiveness.
HPE - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Registered
HP E2Q92AA
Pricing Type
CTO
Workstation Z620, Z820
4 GB
Upgrade Type
System specific
HP E2Q92AA
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Registered
Chips Organization
512 x 4
Compatible Slots
1 x memory - DIMM 240-pin
Pricing Type
CTO
HP Workstation Z620, Z820
£110.61
Save on this ideal PC Build kit!
Save £10.76
£129.78
Scroll to top
