Click to visit BT.com
BT.com
Wishlist
HPE 41B PCIe 4Gb FC SinglePort HBA
Quicklinx: 71DYWS00
Mfr#: AP767A
Accessory Type: HBA Controllers
£840.57
The HP PCIe 4Gb FC Host Bus Adapters (HBAs) support customers using HP ProLiant servers with PCIe I/O slots running a broad range of operating systems. These Fibre Channel HBAs are second generation products that support this new higher speed I/O bus architecture and provide customers the ability to use it to connect to their HP storage arrays.
HPE StorageWorks 41B - host bus adapter
Host bus adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
4Gb Fibre Channel
16.5 cm x 4.3 cm
Cabling Type
Fibre optic
4Gb Fibre Channel (SW)
Data Transfer Rate
4.24 Gbps
Linux, Microsoft Windows 2000, Microsoft Windows Server 2003, SunSoft Solaris 10
3 years warranty
ProLiant DL120 G7, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL580 G5, DL980 G7, SL160s G6; StorageWorks Network Storage Gateway X3400 G2, X3800 G2; StorageWorks Network Storage System X1400 G2, X1500, X1500 4TB, X1500 8TB, X1500 G2, X1600, X1600 24, X1600 3TB, X1600 G2, X1800, X1800 G2
Host bus adapter
PCI Express
Ports
4Gb Fibre Channel
Wired
Cabling Type
Fibre optic
Data Transfer Rate
4.24 Gbps
1 x 4Gb Fibre Channel (short-wave) - LC multi-mode
Compatible Slots
1 x PCI Express
Low-profile bracket, full-height bracket
16.5 cm
4.3 cm
3 years warranty
Service & Support Details
Limited warranty - parts - 3 years
50 °C
5 - 93%
HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G5p Special Server, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Performance, DL165 G7 Special Server, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6 Base, ML370 G6 Entry, SL160s G6 , HPE StorageWorks SN6000C 16-ports Active Fabric Switch, SN6000C 32-ports Active Fabric Switch , HPE StorageWorks Modular Smart Array P2000 G3 FC Dual Controller LFF Array , HPE StorageWorks Network Storage Gateway X3400, X3400 G2, X3800, X3800 G2 , HPE StorageWorks Network Storage System X1400, X1400 2TB SATA Model, X1400 4TB SATA Model, X1400 8TB SATA Model, X1400 G2, X1500, X1500 4TB SATA Model, X1500 8TB SATA Model, X1500 G2, X1600, X1600 12TB SATA Model, X1600 24TB SATA Model, X1600 292GB SAS Model, X1600 3TB SAS Model, X1600 5.4TB SAS Model, X1600 6TB SATA Model, X1600 7.5TB SAS Model, X1600 G2, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 6TB SATA Model, X1800 G2
HPE 41B PCIe 4Gb FC SinglePort HBA Bundle deal on HPE 41B PCIe 4Gb FC SinglePort HBA
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£850.56
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£844.66
saving £0.88
Brand: HPE
Price Range Inc VAT: 750 - 1000
