BT.com
Wishlist
HPE 300 GB Hot-Swap HDD 1500rpm Serial Attached SCSI 2 2.5"
HPE 300 GB Hot-Swap HDD 1500rpm...
£192.14
£192.14
Add to wishlist
Delivery
Standard 1-3 working days
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Enterprise - hard drive - 300 GB - SAS 6Gb/s
Hard drive - hot-swap
300 GB
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
15000 rpm
75.7 mm x 118.7 mm x 15.6 mm
725 g
3 years warranty
Bundled with
HP SmartDrive carrier
ProLiant BL420c Gen8, BL460c Gen8, BL465c Gen8, BL660c Gen8, BL660c Gen9, DL160 Gen8, DL20 Gen9, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, DL580 Gen9, MicroServer Gen8, ML110e Gen8, ML310e Gen8, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4540 Gen8, WS460c Gen8, WS460c Gen9, XL220a Gen8, XL230a Gen9, XL250a Gen9
300 GB
2.5" SFF
SAS 6Gb/s
Bytes per Sector
512
75.7 mm
118.7 mm
15.6 mm
725 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
2.9 ms (average) / 5.3 ms (max)
Track-to-Track Seek Time
0.4 ms
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" SFF
WEEE
Limited warranty - 3 years
10 °C
35 °C
HPE ProLiant BL460c Gen8 (2.5"), BL660c Gen8 (2.5"), BL660c Gen8 Performance (2.5"), BL660c Gen9 (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL360e Gen8 Special Server (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Performance (2.5"), DL360p Gen8 Special Server (2.5"), DL380e Gen8 (2.5"), DL380e Gen8 Entry (2.5"), DL380e Gen8 Storage (2.5"), DL380p Gen8 Performance (2.5"), DL385p Gen8 (2.5"), DL385p Gen8 Dedicated Workload (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Storage (2.5"), DL385p Gen8 Storage Centric (2.5"), DL560 Gen8 (2.5"), DL560 Gen8 Base (2.5"), DL560 Gen8 Entry (2.5"), DL560 Gen8 Performance (2.5"), DL580 Gen9 (2.5"), MicroServer Gen8 (2.5"), MicroServer Gen8 Base (2.5"), MicroServer Gen8 Base Starter Kit (2.5"), MicroServer Gen8 Entry (2.5"), ML110e Gen8 (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML310e Gen8 v2 Base (2.5"), ML350e Gen8 (2.5"), ML350e Gen8 v2 (2.5"), ML350p Gen8 (2.5"), ML350p Gen8 Special Server (2.5"), SL210t Gen8 (2.5"), SL210t Gen8 1U Node (2.5"), SL250s Gen8 2U PCIe Gen3 Left Tray (2.5"), SL250s Gen8 2U PCIe Gen3 Right Tray (2.5"), SL250s Gen8 Left Tray (2.5"), SL250s Gen8 Right Tray (2.5"), SL270s Gen8 1U Left Half Width Tray (2.5"), SL270s Gen8 1U Right Half Width Tray (2.5"), SL270s Gen8 Base 4U Left Half Width Tray (2.5"), SL270s Gen8 Base 4U Right Half Width Tray (2.5"), SL270s Gen8 SE 4U Left Tray (2.5"), SL270s Gen8 SE 4U Right Tray (2.5"), SL4540 Gen8 (2.5"), SL4540 Gen8 Tray 2x Node Server (2.5"), WS460c Gen8 (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5"), XL220a Gen8 v2 (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL250a Gen9 Accelerator Tray (2.5")
Scroll to top
