BT.com
Wishlist
HPE 3.6kVA 200-240 Volt 12 Outlet WW Basic Power Distribution
HPE 3.6kVA 200-240 Volt 12 Outlet...
£167.44
£167.44
Add to wishlist
Delivery
Standard Due date unavailable
With simple 0U and 1U installation options, HPE Basic Power Distribution Units are available in multiple form factors allowing you to configure access to power in your rack where you need it the most. HPE Basic PDUs provide a low-profile single-piece design allowing easy access to rear devices for maintenance. Vertical PDUs can be installed on either side of the rack with outlets facing the back of the rack for easy access and improved clearance. For higher power density configurations, they can be installed side by side on both sides of the rack with the outlets facing towards the center. Horizontal/Modular PDUs offer a modular architecture designed for data center customers who want to maximize power distribution and space efficiencies. The Control Unit or core can be mounted in any 1U space or in 0U space on the side of HPE Racks between the RETMA rails. Extension Bars mount directly to the frame so you can configure access to power where you need it.
HPE Basic Power Distribution Unit 1U/0U - power distribution unit - 3680 VA
Power distribution unit - rack-mountable
2.1 kg
Worldwide
Input Voltage
AC 200-240 V
Output Voltage
AC 200-240 V
Power Capacity
3680 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
12 x power IEC 60320 C13
44.45 cm x 15.3 cm x 4.2 cm
HPE 600, 800; 11000 G2 Series; Advanced Series Racks 42U 600; Apollo 4510 Gen9; ProLiant c3000, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360p Gen8, DL380 Gen9, DL60 Gen9, DL80 Gen9, e2000 G6, m350, m400, m710, m800, ML10 v2, ML150 Gen9, ML350 Gen9, ML350p Gen8
Worldwide
Input Voltage
AC 200-240 V
Input Connectors
Output Voltage
AC 200-240 V
Max Electric Current
16 A
Power Capacity
3680 VA
Circuit Protection
Circuit breaker
No power cord is included
Rack Mounting Kit
Included
UL, TUV, cUL, KC
10 °C
50 °C
10 - 90%
44.45 cm
15.3 cm
4.2 cm
2.1 kg
HPE 600mm x 1075mm Advanced Pallet Rack, 600mm x 1075mm Advanced Shock Rack, 600mm x 1075mm Enterprise Crate Rack, 600mm x 1075mm Enterprise Pallet Rack, 600mm x 1075mm Enterprise Shock Rack, 600mm x 1075mm Kitted Advanced Pallet Rack with Side Panels and Baying, 600mm x 1200mm Advanced Pallet Rack, 600mm x 1200mm Advanced Shock Rack, 600mm x 1200mm Enterprise Air Duct Rack, 600mm x 1200mm Enterprise Pallet Rack, 600mm x 1200mm Enterprise Shock Network Rack, 600mm x 1200mm Enterprise Shock Rack, 600mm x 1200mm Grey Enterprise Air Duct Rack, 600mm x 1200mm Grey Enterprise Shock Rack, 600mm x 1200mm Network Advanced Shock Rack, 800mm x 1075mm Enterprise Pallet Rack, 800mm x 1075mm Enterprise Shock Rack, 800mm x 1200mm Advanced Pallet Rack, 800mm x 1200mm Advanced Shock Rack, 800mm x 1200mm Enterprise Pallet Rack, 800mm x 1200mm Enterprise Shock Network Rack, 800mm x 1200mm Enterprise Shock Rack, 800mm x 1200mm Grey Enterprise Shock Network Rack, 800mm x 1200mm Grey Enterprise Shock Rack, 800mm x 1200mm Network Advanced Shock Rack , HPE 11000 G2 Series 11642 1075mm Pallet Universal Rack , HPE Advanced Series Racks 42U 600mm x 1075mm Kitted Advanced Pallet Rack with Side Panels and Baying, 42U 600mm x 1075mm Kitted Advanced Shock Rack with Side Panels and Baying , HPE Apollo 4510 Gen9 , HPE ProLiant c3000, DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8 v2 Entry, DL360 Gen9 Performance, DL360p Gen8, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, e2000 G6, m350, m400, m710, m800, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, ML350p Gen8
Scroll to top
