Click to visit BT.com
BT.com
Wishlist
HPE 2TB 6G SAS 7.2K 3.5IN DP HDD
Quicklinx: 71FYWS00
Mfr#: 507616-B21
Hurry, only 1 left in stock!
£260.86
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Dual Port Midline - hard drive - 2 TB - SAS 6Gb/s
Hard drive - hot-swap
2 TB
3.5" LFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
18.9 cm x 11.1 cm x 2.6 cm
0.7 kg
1 year warranty
ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance (3.5"), DL370 G6 (3.5"), DL370 G6 Special Server (3.5"), DL380 G7 (3.5"), DL385 G6 Performance (3.5"), DL385 G7 (3.5"), ML110 G7 (3.5"), ML150 G6 (3.5"), ML150 G6 Base (3.5"), ML150 G6 Performance (3.5"), ML330 G6 (3.5"), ML330 G6 Base (3.5"), ML330 G6 Special Server (3.5"), ML350 G6 (3.5"), ML350 G6 Entry (3.5"), ML350 G6 Performance (3.5"), ML350 G6 Special Server (3.5"), ML370 G6 (3.5")
2 TB
3.5" LFF
SAS 6Gb/s
Bytes per Sector
512
18.9 cm
11.1 cm
2.6 cm
0.7 kg
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average) / 16.2 ms (max)
Track-to-Track Seek Time
0.5 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bays
1 x 3.5" LFF - hot-swap
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant DL120 G7 (3.5"), DL120 G7 Base (3.5"), DL120 G7 Entry (3.5"), DL120 G7 Performance (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry (3.5"), DL165 G7 Special Server (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL320 G6 (3.5"), DL320 G6 Entry (3.5"), DL320 G6 High Efficiency (3.5"), DL320 G6 Performance (3.5"), DL370 G6 (3.5"), DL370 G6 Special Server (3.5"), DL380 G7 (3.5"), DL385 G6 Performance (3.5"), DL385 G7 (3.5"), ML110 G7 (3.5"), ML150 G6 (3.5"), ML150 G6 Base (3.5"), ML150 G6 Performance (3.5"), ML330 G6 (3.5"), ML330 G6 Base (3.5"), ML330 G6 Special Server (3.5"), ML350 G6 (3.5"), ML350 G6 Entry (3.5"), ML350 G6 Performance (3.5"), ML350 G6 Special Server (3.5"), ML370 G6 (3.5")
HPE 2TB 6G SAS 7.2K 3.5IN DP HDD Bundle deal on HPE 2TB 6G SAS 7.2K 3.5IN DP HDD
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£264.95
saving £1.39
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 71FY 033524
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £84.48
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
