BT.com
Wishlist
HPE 2GB DDR3 1333 PC3-10600 Memory Module
Delivery
Standard Due date unavailable
HP 2 GB PC3-10600 (DDR3 1333 MHz) SODIMM
Marketing description is not available.
HP - DDR3 - 2 GB - SO-DIMM 204-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
HP 420, 425, 450, 455, 620, 625; EliteBook 2170, 25XX, 27XX, 84XX, 85XX, 87XX; Envy dv6, DV7; Mini 5103; Mobile Thin Client 4320; Pavilion dv6, dv7; ProBook 43XX, 44XX, 45XX, 47XX, 53XX, 6360, 64XX, 65XX
2 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
HP 420, 425, 450, 455, 620, 625 , HP EliteBook 2170p, 2540p, 2560p, 2740p, 2760p, 8440p, 8460p, 8460w, 8470p, 8540p, 8540w, 8560p, 8560w, 8740w, 8760w , HP Envy dv6-7200ea, dv6-7200sa, dv6-7201eg, dv6-7202eg, dv6-7202ss, dv6-7203es, dv6-7210us, dv6-7214nr, dv6-7214tx, dv6-7215nr, dv6-7220us, dv6-7222nr, dv6-7223nr, dv6-7227nr, dv6-7227sa, dv6-7228nr, dv6-7229nr, dv6-7240sg, dv6-7250ca, dv6-7251eo, dv6-7252eo, dv6-7254eo, dv6-7267cl, dv6-7276ez, dv6-7280la, dv6-7280sf, dv6-7290sf, dv6-7300ea, dv6-7300sa, dv6-7302eo, dv6-7370sf, dv7-7201eg, dv7-7202eg, dv7-7202ss, dv7-7203ea, dv7-7205tx, dv7-7212nr, dv7-7215sg, DV7-7230US, DV7-7240US, DV7-7243NR, DV7-7250US, dv7-7252eo, DV7-7259NR, dv7-7270ca, dv7-7290eb, dv7-7292eo, dv7-7299ef, dv7-7299sf , HP Mini 5103 , HP Mobile Thin Client 4320t , HP Pavilion dv6-2137el, dv6-3008et, dv6-3025et, dv6-3035et, dv6-3101et, dv6-3102et, dv6-3104et, dv6-3105et, dv6-3107et, dv6-3112st, dv6-3113et, dv6-3120et, dv6-3320et, dv6-3340et, dv6-6186nr, dv6-6b31eo, dv6-6b48nr, dv6-6c11sz, dv6-6c82sl, dv6-7000sy, dv6-7001em, dv6-7002ed, dv6-7003sm, dv6-7003sp, dv6-7003ss, dv6-7004es, dv6-7009ss, dv6-7010ss, dv6-7013cl, dv6-7014nr, dv6-7024eo, dv6-7024nr, dv6-7030eo, dv6-7030sz, dv6-7041tx, dv6-7050ca, dv6-7050ez, dv6-7050sw, dv6-7053ea, dv6-7054sa, dv6-7055sa, dv6-7063sa, dv6-7070sw, dv6-7082eg, dv6-7086la, dv6-7114nr, dv6-7115nr, dv7-3169wm, dv7-4197cl, dv7-6102er , HP ProBook 4310s, 4320s, 4330s, 4425s, 4430s, 4510s, 4520s, 4525s, 4530s, 4535s, 4710s, 4720s, 4730s, 5310m, 5320m, 5330m, 6360b, 6440b, 6450b, 6455b, 6460b, 6465b, 6470b, 6540b, 6550b, 6555b, 6560b, 6565b
Scroll to top
