BT.com
Wishlist
HPE 2920-48G-POE+ 740W Switch
£3,960.12
£3,960.12
Add to wishlist
Delivery
Standard Due date unavailable
The HP 2920 Switch Series provides security, scalability and ease of use for enterprise edge, SMB and branch office access layer deployments. A powerful HP Networking ASIC delivers low latency, more packet buffering, and adaptive power consumption to this robust Basic Layer 3 switch that supports modular stacking, 10GbE, RIP routing, PoE+, ACLs, sFlow and IPv6. The HP 2920 Switch Series can be managed with the optional HP Intelligent Management Center (IMC) software for a single view of your entire network and is ready for the Software-defined Network (SDN) with OpenFlow support.
Aruba 2920-48G-PoE+ 740 W - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Throughput: 130.9 Mpps , Switching capacity: 176 Gbps
IPv4 routing table entries: 2048 , IPv6 routing table entries: 256
MAC Address Table Size
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
RIP, RIP-2, static IP routing, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SMON, SSH, SSH-2, CLI
Flow control, DHCP support, BOOTP support, ARP support, trunking, VLAN support, IPv6 support, half duplex mode, full duplex mode, SNTP support, sFlow, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), PoE+, STP Root Guard, Uni-Directional Link Detection (UDLD), LLDP support, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet, Class of Service (CoS), Generic Attribute Registration Protocol (GARP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1v, IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
AC 120/230 V ( 50/60 Hz )
44.25 cm x 33.6 cm x 4.39 cm
5.83 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
Encryption Algorithm
SSL, TLS
Authentication Method
RADIUS, PAP, CHAP, TACACS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
1 x ARM ARM1176 : 625 MHz
RAM
512 MB - SDRAM
Flash Memory
1 GB
48 x 1000Base-T - RJ-45 - PoE+ , 4 x - SFP , 1 x management - RJ-45 , 1 x management (micro-USB) - Type B , 1 x USB
Expansion Slots
2 (total) / 2 (free) x Expansion Slot , 1 (total) / 1 (free) x Stacking Module
Power Provided
1050 Watt
487 Watt
C-Tick, GOST, CISPR 24, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, EN55022 Class A, FCC Part 15 B, ICES-003 Class A, RoHS, EN 60950-1, 80 PLUS Silver, IEC 60825-1, EN 60825-1, IEC 60950-1 Second Edition, VCCI Class A
44.25 cm
33.6 cm
4.39 cm
5.83 kg
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.13
Scroll to top
