BT.com
Wishlist
HPE 2915-8G-PoE Switch
£752.83
Hurry, only 1 left in stock!
£752.83
Add to wishlist
Delivery
Standard 1-3 working days
The Aruba 2915 Switch Series provides simple, cost-effective and reliable access layer connectivity for enterprises, branch offices and SMBs. This compact and quiet 8-port, fully managed, Basic Layer 3, Gigabit Ethernet switch with PoE is ideal for deployment in open areas, offices and environments. A robust Basic Layer 3 feature set supports static and RIP routing, sFlow, ACLs, rate limiting, IPv6 and PoE. It is easy to use and deploy, supporting PoE devices and can be managed with the optional HPE Intelligent Management Center (IMC) Software for a single view of your entire network.
Aruba 2915-8G-PoE - switch - 8 ports - Managed
Switch - 8 ports - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
8K entries
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
Flow control, DHCP support, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, manageable, IPv6 support, sFlow, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
16 cm x 9 cm x 4.5 cm
1.7 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE
8K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Freescale
RAM
128 MB - DDR2 SDRAM
Flash Memory
32 MB Flash
Status Indicators
Link activity, port transmission speed
8 x 1000Base-T - RJ-45 , 2 x 1000Base-T - RJ-45 , 1 x console - RJ-45 - management , 2 x SFP (mini-GBIC)
External power adapter
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN55024, UL 60950, CSA 22.2 No. 60950
16 cm
9 cm
4.5 cm
1.7 kg
45 °C
15 - 95%
Scroll to top
