BT.com
Wishlist
HPE 1TB 6G SATA 7.2K rpm LFF (3.5-inch) SC Midline 1yr Warran
HPE 1TB 6G SATA 7.2K rpm LFF...
£135.39
Hurry, only 1 left in stock!
£135.39
Add to wishlist
Delivery
Standard 1-3 working days
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 1 TB - SATA 6Gb/s
Hard drive - hot-swap
1 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL320e Gen8, DL360e Gen8, DL380e Gen8, DL385p Gen8, ML310e Gen8, ML350e Gen8
1 TB
3.5" LFF
SATA 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
Limited warranty - 1 year
Resources
The following resources are available for the HPE 1TB 6G SATA 7.2K rpm LFF (3.5-inch) SC Midline 1yr Warran
Scroll to top
