BT.com
Wishlist
HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD
HPE 1TB 12G SAS 7.2K 2.5 MDL SC...
£233.13
Hurry, only 1 left in stock!
£233.13
Add to wishlist
Delivery
Standard 1-3 working days
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE Server SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE Server SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Midline - hard drive - 1 TB - SAS 12Gb/s
Hard drive - hot-swap
1 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
7200 rpm
75.7 mm x 118.7 mm x 15.6 mm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Base (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 High Performance (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), XL250a Gen9 Accelerator Tray (2.5")
1 TB
2.5" SFF
SAS 12Gb/s
Bytes per Sector
512
75.7 mm
118.7 mm
15.6 mm
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
6.8 ms (average) / 17 ms (max)
Track-to-Track Seek Time
0.5 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Base (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 High Performance (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), XL250a Gen9 Accelerator Tray (2.5")
£233.13
Save on this ideal PC Build kit!
Save £16.90
£258.48
Scroll to top
