Click to visit BT.com
BT.com
Wishlist
HPE 1GB Flash Backed Cache P410i
Quicklinx: 71DVWS00
Mfr#: 534562-B21
Accessory Type: Flash Backed Cache
£343.59
Upgrade the cache on the select controller for increased cache capacity, higher performance, and indefinite data retention.
HPE Flash Backed Write Cache - RAID controller cache memory (1GB)
ProLiant BL460c G7, BL620C G7, BL680c G7, DL160 G6, DL165 G7, DL180 G6, DL320 G6, DL360 G7, DL370 G6, DL380 G7, DL385 G7, DL580 G7, DL585 G7, DL980 G7, ML110 G7, ML150 G6, ML350 G6; Smart Array P410/256MB, P411/256MB; StorageWorks Modular Disk System 600
HPE ProLiant BL460c G7, BL620C G7, BL680c G7, DL160 G6, DL160 G6 Special Server, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 Base, DL370 G6 High Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL980 G7, ML110 G7, ML150 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server , HPE Smart Array P410/256MB Controller, P411/256MB Controller , HPE StorageWorks Modular Disk System 600, 600 with two Dual Port I/O Module System
HPE 1GB Flash Backed Cache P410i Bundle deal on HPE 1GB Flash Backed Cache P410i
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£353.58
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£347.68
saving £0.88
Brand: HPE
Price Range Inc VAT: 300 - 500
