BT.com
Wishlist
HPE 16GB DDR4 DIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2VR registered ECC
HPE 16GB DDR4 DIMM 288-pin 2400...
£303.87
More than 50 in stock
£303.87
Add to wishlist
Delivery
Standard 1-3 working days
Does your server have the memory it needs to perform as its role expands over time? When you choose HPE DDR4 SmartMemory, you get great performance, reliability, and efficiency that provides the compatibility, capacity and bandwidth you need to productively manage your expanding workload with the HPE ProLiant Gen9 server, Apollo Family, Synergy and Blade Systems. The quality and reliability of DRAM are more important now than ever, as data center trends such as server virtualization, cloud computing, the use of large database applications, have all increased the need for higher capacity memory with greater uptime. HPE SmartMemory goes through rigorous qualification and testing processes that unlock extended memory performance features available only with Hewlett Packard Enterprise Gen9 servers. This extensive testing ensures that HPE server memory is completely compatible with and optimized for HPE servers.
HPE - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Single rank, registered
Voltage
1.2 V
HP 805349-B21
ProLiant DL120 Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL580 Gen9, DL60 Gen9, DL80 Gen9, ML110 Gen9, ML150 Gen9, ML350 Gen9, WS460c Gen9, XL190r Gen9; Synergy 480 Gen9, 620 Gen9, 660 Gen9, 680 Gen9
16 GB
Upgrade Type
System specific
HP 805349-B21
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17 (17-17-17)
ECC
Chips Organization
X4
Voltage
1.2 V
HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL360 Gen9 Special Server, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL580 Gen9, DL580 Gen9 Database, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL190r Gen9 , HPE Synergy 480 Gen9 Compute Module, 620 Gen9 2S-EX Base Compute Module, 620 Gen9 2S-EX Performance Compute Module, 660 Gen9 Entry Compute Module, 660 Gen9 Performance Compute Module, 680 Gen9 4S-EX Base Compute Module, 680 Gen9 4S-EX Performance Compute Module
Scroll to top
