BT.com
Wishlist
HPE 16GB 4Rx4 PC3-8500R-7 Kit
Delivery
Standard Due date unavailable
Is finding reliable DRAM memory for your HP ProLiant Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all increased the need for higher capacity memory with greater reliability and uptime. HP SmartMemory is a unique technology introduced for ProLiant Gen8 Servers that unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 systems to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
HPE - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Quad rank, registered
ProLiant BL2x220c G7, BL490c G7, BL620C G7, BL680c G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, SL160s G6; StorageWorks Network Storage Blade X1800sb G2; StorageWorks Network Storage Gateway X3400 G2, X3800 G2, X3800sb G2; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
16 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
ECC
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL2x220c G7, BL460c G6, BL460c G7, BL490c G6, BL490c G7, BL620C G7, BL680c G7, DL160 G6, DL160 G6 Special Server, DL160se G6, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 Performance, DL380 G6 Special Rack Server, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL980 G7, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6 Workstation Blade , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3400 G2, X3800 G2, X3800sb G2 , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
Scroll to top
