BT.com
Wishlist
HPE 16GB (1x16GB) Dual Rank x4 PC4-17000P-R (DDR-2133)
HPE 16GB (1x16GB) Dual Rank x4...
£167.61
£167.61
Add to wishlist
Delivery
Standard Due date unavailable
Maximize your PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
HPE - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Dual rank, registered
Voltage
1.2 V
HP 726719-B21
Apollo 4530; ProLiant BL460c Gen9, BL660c Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL560 Gen9, DL580 Gen9, DL80 Gen9, ML110 Gen9, ML350 Gen9, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9
16 GB
Upgrade Type
System specific
HP 726719-B21
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-15-15)
ECC
Chips Organization
X4
Voltage
1.2 V
HPE Apollo 4530 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen9, DL580 Gen9 Database, DL80 Gen9, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL170r Gen9, XL190r Gen9, XL230a Gen9
£167.61
Save on this ideal PC Build kit!
Save £16.94
£192.99
Scroll to top
