Click to visit BT.com
BT.com
Wishlist
HPE 146GB 15K 6G 2.5 SAS DP HDD
Quicklinx: 6CMMWS00
Mfr#: 512547-B21
Hurry, only 1 left in stock!
£238.03
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Dual Port Enterprise - hard drive - 146 GB - SAS 6Gb/s
Hard drive - hot-swap
146 GB
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
15000 rpm
7.9 cm x 13.8 cm x 1.6 cm
3 years warranty
Integrity BL860c i2, BL860c i4, BL870c i2, BL890c i2; Modular Smart Array 1040, P2000 G3; ProLiant BL460c G7, BL465c G6, BL465c G7, BL620C G7, BL680c G7, BL685c G7, DL160 G6, DL160se G6, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL580 G5, DL580 G7, DL585 G5, DL585 G6, DL585 G7, DL785 G6, DL980 G7, ML110 G7, ML350 G6, WS460c G6; StorageWorks D2200; StorageWorks Disk Enclosure D2700; StorageWorks Modular Smart Array 2324sa G2, P2000 2.5-in, P2000 G3; StorageWorks Network Storage Blade X1800sb G2; StorageWorks Network Storage Gateway X3800sb G2; StorageWorks Network Storage System X1600, X1600 292, X1600 3TB, X1600 7.5TB, X1600 G2, X1800, X1800 292, X1800 G2
146 GB
2.5" SFF
SAS 6Gb/s
7.9 cm
13.8 cm
1.6 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
2.58 ms (average) / 4.85 ms (max)
Track-to-Track Seek Time
0.14 ms
Spindle Speed
15000 rpm
Expansion & Connectivity
2 x SAS 6Gb/s
Compatible Bays
1 x 2.5" SFF - hot-swap
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 °C
35 °C
HPE Integrity BL860c i2 (2.5"), BL860c i4 (2.5"), BL870c i2 (2.5"), BL890c i2 (2.5") , HPE Modular Smart Array 1040 Dual Controller SFF Storage, P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 FC MSA Dual Controller Virtualization SAN Starter Kit, P2000 G3 iSCSI Dual Controller SFF Bundle , HPE ProLiant BL460c G7 (2.5"), BL465c G7 (2.5"), BL620C G7 (2.5"), BL680c G7 (2.5"), BL685c G7 (2.5"), DL160se G6 (2.5"), DL165 G7 (2.5"), DL165 G7 Performance (2.5"), DL165 G7 Special Server (2.5"), DL360 G7 (2.5"), DL360 G7 Base (2.5"), DL360 G7 Central Management Server (2.5"), DL360 G7 Efficiency (2.5"), DL360 G7 Entry (2.5"), DL360 G7 Performance (2.5"), DL360 G7 Special Server (2.5"), DL370 G6 High Performance (2.5"), DL370 G6 Special Server (2.5"), DL380 G6 (2.5"), DL380 G7 (2.5"), DL380 G7 Base (2.5"), DL380 G7 Efficiency (2.5"), DL380 G7 Entry (2.5"), DL380 G7 Performance (2.5"), DL380 G7 Special Server (2.5"), DL385 G6 Performance (2.5"), DL385 G7 (2.5"), DL385 G7 Base (2.5"), DL385 G7 Entry (2.5"), DL385 G7 HE (2.5"), DL385 G7 Performance (2.5"), DL580 G5 Highly Serviceable Tower (2.5"), DL580 G7 (2.5"), DL580 G7 Base (2.5"), DL580 G7 High Performance (2.5"), DL585 G5 Performance (2.5"), DL585 G7 (2.5"), DL585 G7 Base (2.5"), DL585 G7 Performance (2.5"), DL785 G6 (2.5"), DL785 G6 Base (2.5"), DL785 G6 Performance (2.5"), DL980 G7 (2.5"), ML110 G7 (2.5"), ML350 G6 Special Server (2.5"), WS460c G6 Workstation Blade (2.5") , HPE StorageWorks D2200sb PCIe Storage Blade , HPE StorageWorks Disk Enclosure D2700 , HPE StorageWorks Modular Smart Array P2000 2.5-in Drive Bay Chassis, P2000 G3 FC/iSCSI Dual Combo Controller SFF Array , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3800sb G2 , HPE StorageWorks Network Storage System X1600, X1600 292GB SAS Model, X1600 3TB SAS Model, X1600 7.5TB SAS Model, X1600 G2, X1800, X1800 292GB SAS Model, X1800 G2
HPE 146GB 15K 6G 2.5 SAS DP HDD Bundle deal on HPE 146GB 15K 6G 2.5 SAS DP HDD
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£248.02
