BT.com
Wishlist
HPE 12Gb DL380 Gen9 SAS Expander Card
HPE 12Gb DL380 Gen9 SAS Expander...
£417.24
13 in stock
£417.24
Add to wishlist
Delivery
Standard 1-3 working days
Are you looking to expand additional storage within the HP ProLiant DL380 Gen9 Server? The HP SAS Expander Card provides internal storage expansion within the HP ProLiant DL380 Gen9 Server by allowing support for more than 8 internal hard disk drives when connected to a Gen9 supported Smart Array or Smart HBA controller. This full height card supports 12 Gb/s SAS connectivity and features 9 internal ports with a maximum of 26 physical links. The SAS Expander Card is ideal for DL380 Gen9 Server users who want to RAID more than 8 internal hard disk drives or who want to add an additional internal drive cage and RAID across all the internal drives depending on the controller. This option kit contains all the cables necessary to connect the different SAS drive cages supported on the DL380 Gen9 Server.
HPE SAS Expander Card - storage controller upgrade card - SATA 6Gb/s / SAS 12Gb/s - PCIe
Storage controller upgrade card - plug-in card
Bus Type
PCIe
Data Transfer Rate
12 GBps
Supported Devices
Hard drive
Channel Qty
26
1.5 cm x 16.8 cm x 11.13 cm
910 g
ProLiant DL360 Gen9 CMS, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance
Host Bus
PCIe
Storage Controller
Data Transfer Rate
12 GBps
Supported Devices
Hard drive
Channel Qty
26
9 x SAS
1.5 cm
16.8 cm
11.13 cm
910 g
HPE ProLiant DL360 Gen9 CMS, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance
Scroll to top
