BT.com
Wishlist
HPE - DDR3L - 16 GB - DIMM 240-pin
£337.64
£337.64
Add to wishlist
Delivery
Standard Due date unavailable
HPE - DDR3L - 16 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - CL11 - 1.35 V - registered - ECC
HPE - DDR3L - 16 GB - DIMM 240-pin - registered
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Quad rank, Low Voltage, registered
Voltage
1.35 V
HP 715284-001
ProLiant DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special
16 GB
Upgrade Type
System specific
HP 715284-001
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Chips Organization
X4
Voltage
1.35 V
HPE ProLiant DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special
Scroll to top
