BT.com
Wishlist
HP Z27s 27" 3840x2160 6ms HDMI MHL DisplayPort UHD IPS LED Monitor
Delivery
Standard Due date unavailable
Join the Ultra High Definition movement and expand your visual workspace with the HP Z27s 68,6 cm (27") IPS UHD Display, which delivers an extra-large screen with UHD/4K presentation and flexible connectivity and comfort features.
What's in the box
  • AC power cable
  • CD with User Guide, warranty, drivers
  • DisplayPort cable
  • DisplayPort mini cable
  • Monitor
HP Z27s - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
77 kWh
Power Consumption (On mode)
53 W
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, MHL
Screen Coating
Anti-glare
62.56 cm x 6.09 cm x 37.03 cm
5.4 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, TCO Certified Edge, KC, CECP, EPA, ISC, CEL Grade 2, SEPA
5 years warranty
Display Type
Energy Class
Class C
77 kWh
53 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
30 - 135 kHz
Video Bandwidth
600 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
62.56 cm x 6.09 cm x 37.03 cm - without stand
5.4 kg
HDMI , MHL / HDMI , DisplayPort , Mini DisplayPort (HDCP) , 4 x USB 3.0 , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
45
Rotation Angle
90
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x USB cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
61 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 62.56 cm - depth: 24.24 cm - height: 53.59 cm - weight: 7.8 kg , Without stand - width: 62.56 cm - depth: 6.09 cm - height: 37.03 cm - weight: 5.4 kg
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
