BT.com
Wishlist
HP Z27q 27" 5120x2880 14ms DisplayPort 5K IPS LED Monitor
Delivery
Standard Due date unavailable
Redefine life like image presentation with the HP Z27q 68,6 cm (27') IPS 5K Display, which delivers more screen real estate and color clarity with an astounding 5K resolution.
HP Z27q - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
Brightness
300 cd/m²
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
63.43 cm x 21.71 cm x 38.03 cm
7.42 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play
Display Type
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
218
Brightness
300 cd/m²
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, 99% Adobe RGB colour gamut
63.43 cm x 21.71 cm x 38.03 cm - with stand
7.42 kg
2 x DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
360
Plug and Play
AC 120/230 V
80 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 63.43 cm - depth: 21.71 cm - height: 38.03 cm - weight: 7.42 kg , Without stand - width: 63.43 cm - depth: 6.2 cm - height: 38.034 cm
ENERGY STAR Certified
Scroll to top
