BT.com
Wishlist
HP Z24nq Narrow Bezel LED 23.8" Monitor 2560x1440 HD Black
Delivery
Standard Due date unavailable
Enjoy quad HD visuals on the HP Z24nq Narrow Bezel IPS Display,which has an edge-to-edge 60,45 cm (23.8") diagonal screen for easy tiling of multiple displays,plus out-of-the-box color calibration and flexible connectivity for all of your devices.
HP Z24nq - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
41 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.206 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 500000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xDisplayPort, DVI-D, Mini DisplayPort, HDMI (MHL)
Display Position Adjustments
Screen Coating
Anti-glare
54.06 cm x 21.01 cm x 5.09 cm
5.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, CB, CCC, TUV Ergo, FCC, TCO Certified Edge, KC, CECP, CEL, SEPA
3 years warranty
Display Type
Energy Class
Class B
41 kWh
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.206 mm
Pixel Per Inch
123.4
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 90 kHz
Video Bandwidth
250 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Colour temperature, luminance
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic-free glass
54.06 cm x 21.01 cm x 5.09 cm - with stand
5.5 kg
DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-2/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
130 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HP Quick Release 2
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
AC 100/240 V (50/60 Hz)
48 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 54.06 cm - depth: 5.04 cm - height: 32.34 cm - weight: 3.6 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
