BT.com
Wishlist
HP Z23i 23" 1920x1200 VGA DVI-D DisplayPort IPS Monitor
Delivery
Standard Due date unavailable
Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z23i 58,4 cm (23') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
HP Z Display Z23i - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB 2.0 hub
Panel Type
IPS2
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54.4 cm x 24.29 cm x 46.99 cm
6.4 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, CSA, TUV, VCCI, C-Tick, BSMI, GOST, cUL, GS, NOM, WHQL, CB, PSB, MIC, FCC, S Mark, CEL, TCO Displays
Display Type
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 2.0 hub
Panel Type
IPS2
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, colour balance, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
95% colour gamut, anti-glare, 72% NTSC (CIE 1931) colour gamut, 86% colour gamut
54.4 cm x 24.29 cm x 46.99 cm - with stand
6.4 kg
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
1 x DVI cable , 1 x USB cable , 1 x DisplayPort cable
Backlight Life
30,000 hours
Power Supply
Internal
28 Watt
Power Consumption Sleep
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 54.4 cm - depth: 5.1 cm - height: 32.9 cm - weight: 4.19 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
