BT.com
Wishlist
HP Z Display Z23i 23" 1920x1080 8ms VGA DVI DisplayPort IPS LED Monitor
Delivery
Standard Due date unavailable
Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z23i 58,4 cm (23') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
HP Z Display Z23i - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54.4 cm x 24.29 cm x 46.99 cm
6.4 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, CSA, TUV, VCCI, C-Tick, BSMI, GOST, cUL, GS, NOM, WHQL, CB, PSB, MIC, FCC, S Mark, CEL, TCO Displays
3 years warranty
Display Type
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Anti-glare
6.4 kg
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Rotation Angle
90
Height Adjustment
15 cm
28 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Width: 54.4 cm - depth: 5.1 cm - height: 32.9 cm - weight: 4.19 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
