BT.com
Wishlist
HP X331 165W 100-240VAC to 12VDC Power Supply
HP X331 165W 100-240VAC to 12VDC...
£230.44
£230.44
Add to wishlist
Delivery
Standard Due date unavailable
Marketing description is not available.
What's in the box
  • HP X331 165W 100-240VAC to 12VDC modular power supply
HPE X331 - power supply - hot-plug / redundant - 165 Watt
Power supply - hot-plug / redundant - plug-in module
790 g
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power Capacity
165 Watt
8.64 cm x 23.8 cm x 4.04 cm
HPE Aruba 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power Capacity
165 Watt
8.64 cm
23.8 cm
4.04 cm
790 g
Scroll to top
