BT.com
Wishlist
HP Value Serial/USB Receipt Printer United Kingdom UK English
HP Value Serial/USB Receipt Printer...
£225.81
£225.81
Add to wishlist
Delivery
Standard Due date unavailable
Complete your retail solution with the HP Value Serial/USB Receipt Printer, a single-station thermal receipt printer designed for solid performance and reliability in retail environments.
HP Value - receipt printer - monochrome - direct thermal
Printer Type
Receipt printer - direct thermal - monochrome
1.47 kg
German / Germany
Max Resolution (B&W)
203 dpi
USB 2.0, serial
RAM Installed (Max)
128 KB
Flash Memory Installed (Max)
2 MB
Barcodes
Code 93, Code 39, UCC/EAN-128, GS1 DataBar, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, PDF417
Media Type
Receipt paper
AC 120/230 V
Microsoft Windows XP Professional, Microsoft Windows Embedded POSReady 2009, CentOS 5.0, Microsoft Windows 7 Professional (32/64 bits), CentOS 6.0, Microsoft Windows Embedded POSReady 7 32-bit, Windows 8 Pro (32/64 bits), Windows 8.1 Pro 64-bit Edition, Microsoft Windows Embedded POSReady 7 64-bit, Windows 8.1 Pro 32-bit Edition, Windows Embedded 8.1 Industry, SUSE Linux Enterprise Point of Service 11 (32/64 bits)
3 years warranty
14.4 cm x 18.5 cm x 13.4 cm
Printer Type
Enclosure Colour
HP carbonite
German / Germany
Printer
Built-in Devices
Status LCD
Wired
USB 2.0, serial
203 dpi
Columns
56, 44
Auto Cutter
Barcodes
RAM
RAM Installed (Max)
128 KB
Flash Memory
Flash Memory
2 MB
Media Handling
Media Type
Receipt paper
Media Thickness Range
0.05 mm - 0.09 mm
1 x USB 2.0 - 4 pin USB Type A , 1 x serial - 9 pin D-Sub (DB-9)
1 x USB cable - 1.83 m , 1 x serial cable - 3 m
Media Included
1 thermal roll paper
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
60 Watt
Power Consumption Stand by
1.2 Watt
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 3 years
5 °C
50 °C
10 - 90% (non-condensing)
14.4 cm
18.5 cm
13.4 cm
1.47 kg
Scroll to top
