BT.com
Wishlist
HP v243  1920 x1080 HP LED 24" Monitor
HP v243 1920 x1080 HP LED 24"...
£156.79
More than 50 in stock
£156.79
Add to wishlist
Delivery
Standard 1-3 working days
Get plenty of room to multi-task across your documents and e-mail and leave multiple windows open side by side with the HP V243 60.96 cm (24") LED Backlit Monitor, an extra-large display that's available at unbelievably low price point.
HP v243 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
56.54 cm x 23.19 cm x 41.19 cm
3.46 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, TUV S, CB, CCC, PSB, FCC, KCC, ICES, KC, CECP, CEL, EPA, TCO Displays 6.0, ISC, SEPA
1 year warranty
Display Type
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Mercury free, arsenic-free glass
56.54 cm x 23.19 cm x 41.19 cm - with stand
3.46 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-4/+22
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
32 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 56.54 cm - depth: 5.65 cm - height: 33.99 cm - weight: 3.02 kg , With stand - width: 56.54 cm - depth: 23.19 cm - height: 41.19 cm - weight: 3.46 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
10 - 90% (non-condensing)
Other bundles
£156.79
Wireless keyboard and mouse set
£206.78
£156.79
Keep your electronic devices protected
£176.78
Scroll to top
