BT.com
Wishlist
HP V213a 52.57 cm (20.7") Monitor
Delivery
Standard Due date unavailable
Enjoy stunning Full HD presentation of your visuals and quality, integrated speakers with the stylish HP v213a 20.7" diagonal monitor, a budget-friendly display that's just right for everyday business.
HP v213a - LED monitor - Full HD (1080p) - 20.7"
LED-backlit LCD monitor - 20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.238 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
48.94 cm x 19.76 cm x 36.27 cm
3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, VCCI, CB, CCC, FCC, WEEE, CEL, EAC, ISO9241-307
1 year warranty
Display Type
Diagonal Size
20.7"
Viewable Size
20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.238 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, On-screen Digital Controls, Mercury free, arsenic-free glass
48.94 cm x 19.76 cm x 36.27 cm - with stand
3 kg
Audio
Speakers
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+11
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable , 1 x audio cable
28 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 48.94 cm - depth: 19.76 cm - height: 36.27 cm - weight: 3 kg , Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80%
Scroll to top
